Hello everyone. I have a 2003 base Vibe(90k miles) that I love and recently had 4 new Continentals mounted. It rides quite and smooth, except that occassionally the steering wheel will shimmy/wobble left to right sometimes up to an inch or so. Its dramatic around 60mph. The car however still goes straight down the road, no noticable pull. Now the trick...it doesn't happen all of the time. I think under load brings it out or hard braking but i am not able to always replicate it. Now the car probably hasn't been raised off the ground in at least a year and i'm thinking that this may be a suspension, joints, bearing issue. I bought the car at 68k miles about 5 years ago and haven't had to touch it. Regular inspections and maintenance is all.
Is there something typical I should start with?
I remember reading somewhere that when the bearings go, you can't check them by just feeling for play up down side to side, is that true?
