What went wrong!!
Txchef
What went wrong!!
Post by Txchef »
2005 Vibe GT. Has the 1.8L "L" series Yamaha designed engine. 148,000 miles
Driving home and the engine check light came on, since I was only about 4 miles from the house I thought I would just check it then, about 2 miles down the road engine starts to rumble and dies...
Got it home, noticed that serpentine belt was missing, figure it broke and was problem. When I was changing the belt out found out that water pump had cratered and was reason the belt came off. Changed out water pump, new belt. Engine turns over but will not catch...haven't pulled engine codes yet...just ran out of time.
What are any possible things to check as to why it won't start up...yes I am thinking the worst... :cry:
Chiadog
Re: What went wrong!!
Post by Chiadog »
I am also thinking the worst! 4 miles is way too far to go for an engine without cooling. Start by checking engine compression - it will let you know the state of your internals!
Good luck,
zythr
Post by zythr »
Agreed, Replacement engine time.
Txchef
Post by Txchef »
Ok...compression is from driver side to passenger side cylinders.
60,30,0,20...
I am thinking this is a bad, bad sign...any chance that it could be a blown head gasket (in other words is it worth pulling the head to see) or it that pretty much a sure sign of major engine failure...
jake75
Post by jake75 »
Did the temp gauge/warning never trigger?
Salsa Guy
Post by Salsa Guy »
You do a wet test on the compression? I've heard head gaskets can be issues on the 2zz engine. Goodluck
SeattleJeremy
Post by SeattleJeremy »
Cross your fingers and pull the head. As Salsa Guy alluded to maybe the engine just overheated, and blew the head gasket (ideal) or maybe warped the head (less ideal).
thebarber
Post by thebarber »
Compression should be about 200
New engine time.
Txchef
Post by Txchef »
Temp gauge never went high, check engine light came on and I looked at all the gauges nothing out of norm. Last time check engine light came on was because the gas cap wasn't on right.
Gonna do a wet compression test, then probable pull the head to see what damage is. Anything to watch for when pulling the head on vibes?
hotbug1776
Post by hotbug1776 »
Txchef wrote:Temp gauge never went high, check engine light came on and I looked at all the gauges nothing out of norm. Last time check engine light came on was because the gas cap wasn't on right.
temp gauge wont read accurately unless there is some fluid in the system... if the coolant was gone, it might have never moved. I'm with the general consensus, your engine is toast.
triz
Post by triz »
Bent valves? Your compression numbers are bad.
