Depending on what tire you put on the rim...the cirumferance/ height of tire is limited to about that of a 215-60-16. I have 215-60-16 Fussion tires and when new they rub a bit on the molded mudflaps at full turn. Visually I wish I could go a bit bigger to fill the wheelwells but it is what it is. 09 model. It was a 5.2% increase from the base 205-55-16 but only a 2% raise from the GT stock tire. Just going from a 205-55-16 to a 205-60-16 is a 3% raise. My 04 got the 205-60-16, much better look in the wells.
I would say I lost a bit of mileage as it slips into passing gear a bit more often on hills. Mpg calculations are a bit off as the tires are 5.2% bigger but the speedo is almost dead on now. Still one mile too high at most speeds.
Hey, I just found out that if mistakenly put a u into the word bigger, it gets censored
2004 Fusion Orange, bought new R.I.P. 2009 Carbon Grey 2.4, bought new. 2004 Neptune bought used-2013
