.Kincaid wrote:
I do not know about towing. I second the addition of the SRI. I'd like to get one myself. The only other thing for mpg that I can think of is the old trick of pumping up the air pressure in the tires to about 40 psi. Believe it or not this also takes some of the harshness out of the ride, I think because you are getting a bit more space between the ground and your rims. You could maybe add a better flowing exhaust system but 1) it isn't needed for sound if you have the SRI and 2) it is expensive and I doubt you'd ever recover on the investment
Since I now have my own air compresser to put air in my tires, I just went ahead to have all of the tires inflated to 40 PSI. A bit of history....When I had the 2009 Vibe new for a about three months, I found that the tires were inflated to 40 PSI and I wasn't really complaining about the harshness over rough roads and potholes. After my "shock" of the high tire pressure, I reduced it to the 32/32 psi as per the card. It was after doing that that I started to feel all the road harshness (using Goodyear RA OEM 17") tires. I since also adjusted the pressure to different rates and felt that 35f 33 rear was ok, still getting a harsh ride.
After taking a short ride around town, with 40 PSI pressure, I felt that the car floats over the rough road surfaces or road patches and cracks in the road. I feel that it is more smoother and even quieter then before.
While adding the air to one of the tires, I found that a circle crack is starting to form on the sidewall face. Now I'm thinking that with correct or lower pressure, the sidewalls are flexing to much over bumps and potholes and that flexing is causing the harshness. Now with a higher pressure and making a stiffer sidewall, the tire will not flex but bouce over the bump.
I'll let you know about how the car feels after a longer run of driving.
