Hey, y'all. The key key fobs on my 2003 GT M&T started working intermittently (and a little strangely--honking slightly but not unlocking), both at the same time, and now don't work at all despite the fact that the light flickers brightly when I hit each key. I tried the procedure for teaching the system new key fobs and everything worked up to the point where it needed to take input from the key fobs, so I suspect there's an issue with the receiver (or RCDLR). My problem is that I've checked through the maintenance manual and looked online and haven't found a good image of exactly where it's located. Does anybody know? Seems to be in the trunk somewhere. If nobody knows, I'll tear in and find it and report back, but I would love to avoid the search part of the equation.
Thanks!
P.S. the part number is 88969656 if that helps.
