I'm selling my TRD S/C as I will be selling my car or parting it out if it does not sell..going to get back into a jeep, here it is: http://www.ebay.com/itm/171043824625?ss ... 1555.l2649" onclick="window.open(this.href);return false; thanks for looking...
*03 SIKVIBE*Performance mods in order:18x8 Konig illusion rims w/ falken ziex 235/40R18 tires~1.5" lowered TEIN S. tech springs~GM performance parts supercharger~TRD add-on ECU for S/C~Drop in spectre high flow air filter~Tripod center dash oil pres.,egt/boost, a/f guage pod~Homemade .5" custom S/C thermal intake spacer~1.9" aluminum S/C pulley~150 psi>530cc nozzle water/alcohol injection system~2.5" single cat proflow muffler opposite exit install
Steven, If your speaking of the AEM piggy-back ECU the answer is yes, unless it sells with the S/C
hotbug, I fabricated it myself using a 1/2" rubber stopper plug and a 1/8" of plate steel, very easy to make just used a saw and a drill press..oh, and a grinder to round of the edges.
You are looking at 150+ hp at the wheels with a good tune and is about a 30% gain. The AEM FIC is a Piggyback, not a "Chip". "Chips" generally speaking are junk for these cars.
Up to 6 cylinders, includes software, usb connector, and piggy-back FIC ecu controller..all you would need, is to purchase a wiring harness and get a tune.
