Hi guys. I've been looking at this forum for years due to all the useful information on it, but I finally found an issue that I wasn't able to solve based on someone else's post.
My 2005 base model Vibe's cooling fan broke on me. The fan came off of the motor and I was unable to reattach it. Instead of spending $270 on an OEM fan and shroud I got the after-market Hayden based upon the recommendation of the local O'Reily store. It attaches directly to the radiator and seems to be working correctly. It's rated at about 650 CFM of airflow.
Unfortunately the car is still overheating on warm days in stop-and-go traffic. It doesn't overheat at idle, it doesn't overheat above 35 MPH, and if it's overheating and I turn on the heater the heat will drop down to normal (after a bit).
This tells me that the coolant is running through the radiator (and into the heater core) correctly, the thermostat is working correctly, and the water pump is working correctly.
My hunch right now is that the aftermarket fan can't push enough air, but I can't confirm that because I don't know the CFM rating for the OEM fan. I know it's a Denso, but that's about it. All the sites I've checked don't tell me the airflow rating.
Does anyone know the airflow rating for the OEM cooling fan on the 2005 1.8L 2WD Vibe?
