hazard, defrost, and all of my climate control lights have gone dark. what bulbs if any are available for purchase. Also I cannot remember if the A/C and recirculation icons were illuminated at some point, the green lights still work.
Sounds like a fuse. A wiring diagram would be helpful, if you have one. Otherwise check each and every associated fuse in the two fuse panels (generation 1 at least)
Yea, did they all go out at the same time?
It's really unlikely that they all burned out at once, unless there was a major electrical spike on that circuit.
As Chiadog said, check the fuses.
no... they have all gone out at different times... just now the last have burned out... i have discovered they are tiny bulbs attached to a brown or white colored fastening device of sorts... prob dealer only item... FML.
If you can figure out the bulb types (likely on the base) you can get direct fit replacements from all sorts of places, first that comes to mind is replacing with LEDs from superbrightleds.com, I've ordered from them a few times.
