Hi All,
I have a 2003 Matrix XRS with the Moon & Tunes package. I've had the car it's entire life.
Fairly recently, my driver's side door speakers (tweeter & woofer) have been intermittently working. It started this winter, on a very cold morning I noticed no sound coming out of them when I turned the radio on. Upon closer inspection, if I moved the fade & balance to isolate the front driver's side door, you could hear just a tiny bit of audio coming out of the tweeter (staticy sounding) but nothing else.
After the car warmed up the speakers would start working again just fine. Fast forward a few months, the driver's side door speakers became more and more intermittent in their functionality and now they barely ever work.
I replaced the HU with a Clarion CX501 a week ago to see if that would help the problem (got the wiring all done correctly, GM05B harness etc.), and tried it with and without the built in amp (just by disconnecting the connector that goes into the amp), and the problem remains. Note that when the driver's side door speakers do come on, they sound just fine.
Since the speakers sound fine when they work, it would seem that there's a loose connection somewhere. I'm curious - has anyone else had a similar issue? What would you recommend as troubleshooting steps? I'm thinking inspecting the speaker wires behind the harness and/or in the door, but not sure what else to try.
Any suggestions are greatly appreciated.
-Dirk
