2009 Vibe GT wheels on 2004 Vibe Base
sgary
Post by sgary »
Ok, so I just got a great deal on a set of 2009 Vibe GT wheels, and I find out that the offset is 5x114.3 on the 09 gt wheels, and my vibe has a 5x100 offset.
I found some wheel adapters that are 1 inch thick, has anyone used these or experienced any issues?
Re: 2009 Vibe GT wheels on 2004 Vibe Base
Not recommended as the adapters will push out your wheels a full inch, so you will probably hit the fenders with the tires. They would look nice, and I wish I could have put them on my son's 06, I but ended up getting some of the 17" alloy wheels instead since I knew they would fit.
Since you have them, maybe you can try to mock them up, like getting a piece of 1" wood to use as a spacer and see how much farther they stick out than the stock ones.
09Viberator
Post by 09Viberator »
i believe Konig has some rims that look really similar to the 09/10 GT rims but i will look into it....
REN69
Post by REN69 »
offset is the distance of the mounting points from the center of the wheel... usually a 1-2 digit positive or negative number like +45, 0(zero) or -15, etc...
you're describing Bolt Pattern when you say 5x114.3 or 5x100. :)
1984 Supra RWD - my beater -- 2004 Vibe AWD - wife's beater -- 2005 Corolla XRS - my daily
sgary
Post by sgary »
I bit the bullet ordered the wheel adapters, and had a brand new tires installed on the rims, and mounted them up, and here's what it looks like...
sgary
Post by sgary »
Now the speedo is just a hair off, now I need to figure out how to recalibrate it....
Looks good from the side. How does it look from the front & rear? Do they stick out much?
sgary
Post by sgary »
I will have to take more pictures and get them up, but no does not really stick out they are within the tops of the wheel wells.
The wheels look great! It's just so weird to see them on a 1st gen Vibe :P!
sgary
Post by sgary »
Thanks for the compliment, actually I am used to looking at them now, and the stock rims on my blue vibe don't look normal now.
It is amazing how much better the car handles now too with the performance tires on it, takes corners real well, it feels like a totally different car when driving it.
salocin
Post by salocin »
Just curious how the car rides now ?
