09SnowyVibe wrote:More than likely the intermediate steering shaft is dry on the lube. It producess the heavy rattle you feel in the steering wheel.I am about to atattempt to take mine apart and grease it. Will keep you posted.
You have an '09 which is quite different from '08 and earlier. I believe you have the electric power steering, which is the cause of the clunk in these cars.
'08 and earlier, the sway bar is bolted down to the K frame and could be loose. Truthfully, it sounds like the OP is experiencing what almost all people who lower their cars experience when they mess with the suspension ride height, is that it is bottoming out.
You can see a number of pics of the suspension in my TRD sway bar swap out thread.
viewtopic.php?f=26&t=38341" onclick="window.open(this.href);return false;
Charles
