2005 Moon & Tune: I noticed that my RAD fan wasn't coming on when I turned on the defrost anymore. This is new. Is this something that is a normal, common easy fix (relay, fuse, ect.) Are there any tests I need to run?
When I was poking around under the hood I noticed a clicking coming from a sensor/relay mounted above the air box. It seems to be clicking constantly. This can't be right! That should wear sensor/relay out quickly. Does anyone know what that is?
Please help if you know the answer. Thanks in advance!
