THINGS TO PROCURE:
2200 grit WET sand paper
a rubbing compound (the coarser grit will be great followed by an optional finer grit)
1 brillo pad/microfiber cloth for applying rubbing compound
1 clean rag
1 rag/spray bottle to wet lenses
water
(can get most items at Autozone or O'rielys auto parts stores and its fairly inexpensive)
STEP 1:
Wet lens with the water.
STEP 2:
sand the entire lens with the sandpaper (be careful around the edges so you don't take the finish off of your paint)
*Make sure that the lens stays wet as your sanding*
Periodically check the lens by rubbing it with your fingers. It should feel very smooth and a little sticky to the touch without any nicks or pits
nicks and pits can be worked out. Be patient
STEP 3:
Once the lens is smooth, apply rubbing compound (its like waxing a car. follow directions on the rubbing compound)
rub the compound in by using small circles and be sure to get the entire lens.
STEP 4:
Wipe off the excess compound.
you dont have to, but you can go over the lenses again with a finer grit rubbing compound for an even better finish.
STEP 5:
Post your success on genvibe!
