2004 vibe gt 6 speed trans oil
sailorbryan13
Post by sailorbryan13 »
Hello im looking at replacing the oil in my trans and have looked all around on genvibe and have found alot of info for the 5 speed but not alot for the 6. i was wondering whats best to run in that trans. i have found alot of people recomend red line 75w90 gl-4 gear oil. is that what i should use and also how much dose that trans require thanks for your help :D
Bryan in oxford
2004 vibe gt
2003 aztek
1972 c10
1953 ford customline
thebarber
Re: 2004 vibe gt 6 speed trans oil
Post by thebarber »
Redline is great
Amsoil severe gear is good too
biodieselrabbit
Post by biodieselrabbit »
I can only weigh in on my experience with the 5-speed but yes the Redline MT-90 (GL-4) gear oil helped shifting at lower temperatures much better than the Valvoline 75W90 (GL-5) I had originally put in. The owners manual should tell you how much to put in when doing a simple drain and refill.
2003 Pontiac Vibe
sideshowalan
Post by sideshowalan »
Redline MT-90. Easy choice.
I attribute the longevity of my 'doomed to fail' 5-speed to this stuff.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Wiretap
Post by Wiretap »
I had an 03 GT 6spd...I used Honda Manual trans fluid..it shifted perfectly cold or hot. Bought it at the Honda dealer but a good euro parts store will carry it. Highly recommended by some Honda 'experts' I know.
revstohigh
Post by revstohigh »
i just ordered 3 quarts of red line and a pump to re fill with
waiting on ups now
03 GT, t3/t40e rear mounted, aem fic,550cc inj, mwr fuel pump, 2 row rad, trd thrmostat, wmr shifter, tokico struts, st springs, progress bars, 17x7 235/45
Vibe4Me
Post by Vibe4Me »
I use Royal Purple Max Gear 75W-90. Loving in NWFL we don't see a lot of cold weather. Works great, smooth shifts.
'04 Salsa GT, Sunroof
thebarber
Post by thebarber »
Pump to refill? Huh?
revstohigh
Yea it fills from the side so im goina pump it in so it dosnt spill all over
revstohigh
put the red line in last night , deff shifts noticably better . its about 10-20 % easier to get into 1st & R , jams 2nd a little easier too . deff recomended !
