Hi All,
I Just posted a problem with my cruise control, and have one more issue to request help on. I have an 2003, and have had the check engine light come on. I brought it in to have the code checked, and it showed that its a "running too lean" code. The symptoms are after driving it for say 30 plus miles and stop, attempting to restart, I have to pump the gas a little as if the "choke" is not working. I have been told it is probably a vacumm hose or an O2 sensor issue. Has anyone run into this before, and what did you check to fix the issue?
Thanks,
Terry
