1. Pass fender was replaced and the replacement was one of those black primered jobs that was never painted and is rusting. (But I will ether look for a replacement fender in that same color or get a good looking one of a different color and have it painted) Or i may just leave it
2. drivers side corner light has a crack on it(still very functional and will replace whenever)
3. Rear view mirror is loose(will tighten up or replace from a junk yard)
4. Belt molding(that rubber strip that attaches to the middle of the door) is missing on the drivers side and damaged on the passenger side(Subaru and GM have issues with those plastic white clips that hold the belt molding cracking and breaking off due to vibration and heat/cold cycles. I may remove them all and fill the holes as it looks more streamlined that way
5. Needs a new battery, it starts up but owner says if left a week or so it will be dead(the battery is old) (battery bought and awaiting placement in car)
6. Needs gas cap door(ether junk yard or a locking cap
Here are some of the sellers pics, more pics when I get it home
It has some dents and wear and tear but it be 20 years old and roamed the roads of Baltimore/Silver Spring and the Beltway
Other then that, it is good condition and nothing prevents me from driving it right a way after tagging it
