Will a Vibe GT hit lift in reverse
robdog
Post by robdog »
Just curious. Does anyone know if lift will kick in when in reverse. I don't have the b***s to try it going that fast. Any one more daring than me let me know......
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
cohocarl
Re: Will a Vibe GT hit lift in reverse (robdog)
Post by cohocarl »
quote:I don't have the b***s to try it going that fast.Would probably take your mind off of that reverse beeper for a second or two.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
NovaResource
Re: Will a Vibe GT hit lift in reverse (cohocarl)
Post by NovaResource »
Probably. The engine doesn't know the difference between the gears. I wouldn't try it however.
Sub-Vibe-R
Re: Will a Vibe GT hit lift in reverse (NovaResource)
Post by Sub-Vibe-R »
I think the same as Nova. The tranny made the difference between going foward or backward. Lift is linked with the rpm. So, we should be able to hit lift in reverse. To try it, jack up the front and go ahead!
NovaResource
Re: Will a Vibe GT hit lift in reverse (Sub-Vibe-R)
quote:To try it, jack up the front and go ahead!I wouldn't try that. Revving an engine to that RPM with no load on it could cause damage. seriously.
Lancer
Post by Lancer »
quote:Just curious. Does anyone know if lift will kick in when in reverse. I don't have the b***s to try it going that fast. Any one more daring than me let me know......That's the funniest thing I heard this week! Thanks! It would make for a funny commercial. Some goofy guy playing with lift on a street, stops, makes the quizzical look, throws it in revers and he goes off screen then you hear the lift kick in and a Yahoo from him. By the way, what made you think of this?
satur9
Post by satur9 »
really!! i rev my engine all the way up in neutral constantly. in fact i was told that was the only way to measure max tps voltage. mabey that why my car isnt faster than 17.3 stock. mabey i should stop. or is this only pertains to gt's.
satur9
Re: Will a Vibe GT hit lift in reverse (satur9)
Post by satur9 »
probably the fast and furious!
savedbyzero
Post by savedbyzero »
This has to be one of the funniest posts I've seen! That's a great question!
THIS IS WHAT I DO...http://www.studiothisis.com
NovaResource
quote:really!! i rev my engine all the way up in neutral constantly.All the way to 8200-rpm?!? I wouldn't.quote:in fact i was told that was the only way to measure max tps voltage.You measure TSP voltage with the engine off but the ignition on.
goodvibe
Post by goodvibe »
Not if it's cold. LOL Best laugh this week.
NovaResource
Re: Will a Vibe GT hit lift in reverse (goodvibe)
Dyslexia. I was thinking TPS (throttle position sensor) not TSP. DOH!
IceCold
Post by IceCold »
yes...to answer the question...i got pissed because i was lost one day and canned it in reverse to get back to a street i passed. lift hit at the usual spot. scared the f**k out of me. i then knew what it felt like to be thrown forward from accelerating. kinda felt like i slammed on the brakes. so hope that answers your question, im the dumbass who did it
2k3 Vibe GT (Monotone Black)-Sylvania SilverStars-Injen CAI-JBL W10 GTI-Rockford Fosgate 550s
AKLGT
Post by AKLGT »
quote:Would probably take your mind off of that reverse beeper for a second or two. speaking of beep, anyone know if that can be stopped? just a quick question. and no, i have not looked it up in search.
AKLGT1998 Subaru 2.5RS
ragingfish
Re: Will a Vibe GT hit lift in reverse (trdvibe)
Post by ragingfish »
From http://forums.genvibe.com/zerothread?id ... 2quote:The actual beeper is inside the instrument panel. If you want to silence the reverse beeper (but keep all other beeping), cut the wire in pin 5 of the instrument panel wiring harness. It is a red wire with a thin black line. To do this you need to remove the instrument panel. First simply pull out the chrome trim ring panel. Next remove the single (!) screw right above the speedo. Then use a screwdriver to push down the 2 tabs that hold the panel in below the tach and below the temp guage. Then carefully pull the panel out. Disconnect the wiring harness. You can look on the back of the panel where the harness plugs in to see where pin 1 is labeled. From there find pin 5 and pull it out or cut it (be sure to leave enough to reconnect it if you need to). If you just want to make all your Matrix beeps quieter, don't cut any wires. Instead remove the back cover of the instrument panel. The beeper is round, black, and about 5/8 inch in diameter, located at the bottom center. I imagine you could just cover it with some foam tape or something. It is definitely nice to be rid of that annoying beeping!
2009 PONTIAC G8
drunkenmaxx
Re: Will a Vibe GT hit lift in reverse (ragingfish)
Post by drunkenmaxx »
the car is supposed to beep in reverse??
millster
Re: Will a Vibe GT hit lift in reverse (drunkenvibe)
Post by millster »
quote:the car is supposed to beep in reverse??Only the Vibe GT and Matrix XRS.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
1986 Jaguar XJ6 Vanden Plas (GM Drivetrain Conversion)
2007 Outback XT EJ257 2.6L Build
satur9
Re: Will a Vibe GT hit lift in reverse (millster)
Post by satur9 »
i have a five speed nova. the guy told me the voltage is slightly higher with the engine off than on and to get the RIGHT voltage do it while the car is running. he may be full of s*** but it doesnt matter now. i wanted to correct for my big fat aftermaket pedal covers not letting my pedals go all the way down. but instead i just tossed them , i got celica gts pedals(including dead pedal) on the way. perfect size and they look better.
canadavibegt
Post by canadavibegt »
quote:really!! i rev my engine all the way up in neutral constantly. in fact i was told that was the only way to measure max tps voltage. mabey that why my car isnt faster than 17.3 stock. mabey i should stop. or is this only pertains to gt's.Wow you must have lots of money cause your gonna need a new engine sooner than you think. No engine should have the (removed) reved out of it.... especially in neutral... Must be too much Fast and F&*&& up Watching.....
Canada Rocks View pics of my car here. http://www.cardomain.com/member_pages/v ... _id=345207
coratz
Re: Will a Vibe GT hit lift in reverse (canadavibegt)
Post by coratz »
i'm actually a non gt owner and a base vibe owner. im still curious on the fact if a vibe will hit lift in reverse? im also interested in a soundclip!!!!! rrrrrrrrrrrrr then ....... blammmpp rrrrrrrr lol!!!!(guys dont't do that to your cars im just joking)
Yoda
Re: Will a Vibe GT hit lift in reverse (coratz)
Post by Yoda »
This is a good forum - I can already hear the eyewitness after the bank robbery and the botched getaway - "I don't know what it was officer - it looked like a pea-green station wagon, made noises like a garbage truck, sounded like a pissed off go-kart, and was moving pretty fast when it hit the tree. He did have time to turn on his headlights though..."
My old Abyss GT - Power, Moon and Tunes, Monochrome Mods - Installed , then removed, Sylvannia Silverstars (Headlamp only)Future mods - ?
pissedoffgokart
Re: Will a Vibe GT hit lift in reverse (Yoda)
Post by pissedoffgokart »
Ahh, the joys of internet access hve returned!!! Yoda - why ya gotta use my name in vain?IceCold - Tell me you are BSin' on that! I couldn't imagine the look on your face when the lift kicked in!!!!!!
Yoda
Re: Will a Vibe GT hit lift in reverse (pissedoffgokart)
Post by Yoda »
Not for nothing, I actually like that sound. When it was summer around here and I was using lift to merge / pass people, you should've seen the looks on their faces at that moment : Smug look, instantly replaced by "What the ...". The one time that didn't work was with a WRX driver that had the sense to shift down into second well before I got to 6G. Ah well there's always a angrier go-kart, I guess. How'd you lose your e-access?If it makes you feel any better, I've placed your royalty check in the mail. Now if only I could get that Lucas guy to send mine...
pissedoffgokart
Thank you, and I hope George pays up soon! I moved from New Mexico to Denver, and it took about a month to get everything back in order!
stellarhavoc9
Post by stellarhavoc9 »
A MatrixXrs Owner in the Bay Area tried hitting lift in Reverse.. and his engine just cut off.. wouldnt allow him to do it....
InjenCAI BorlaExhaust TRDstb ProgressRSway EibachSportlines SunHyperground 17"Enkei5+w/FalkenAzenisST115 SolarguardQuantum RazoInteriorGoods InfinitiBasslinkX ClarionFMModulator VentVisors SunroorWindDeflector ExteriorStylingVinyl HellaSupertones TTStubbyAntenna VIS-CFHood BillitGrill SparcoHoodpins
Stang2Vibe
Re: (stellarhavoc9)
Post by Stang2Vibe »
Engine might not have been warm enough. The engine coolant temperature must be warm enough or the ECU won't send the signal to engage lift.
redlava
Post by redlava »
Quote, originally posted by Yoda »This is a good forum - I can already hear the eyewitness after the bank robbery and the botched getaway - "I don't know what it was officer - it looked like a pea-green station wagon, made noises like a garbage truck, sounded like a pissed off go-kart, and was moving pretty fast when it hit the tree. He did have time to turn on his headlights though..."ROTFLMFAO!!!!!Nice.If somebody wants to hit lift in reverse, just let me know which hospital to send the flowers to.
RcRacer440
Post by RcRacer440 »
I have a GT and floored it in reverse and the car automatically kicked it into neutral at around 30...it didnt lift or anything. It did surprise the crap outta me though.
2003 Lava 2-tone GT:Remote Start,Borla exhaust, K&N intake, orange undercar neons, 7 color undercar L.E.D.s, stobe lights, spoiler, moon & tunes, grafxwerks,satelite radio, PA system Pics of my Vibe http://www.cardomain.com/memberpage/373589
AKLGT
Re: Will a Vibe GT hit lift in reverse (RcRacer440)
Post by AKLGT »
good to know. i'll remember that for next time....
Stang2Vibe
I'm gonna have to try this late at night after work sometime. We have a big, long parking lot where I can safely test this for myself. I can't see mechanically how the car could shift itself into neutral at 30 MPH going in reverse. I would think that if the engine was warm enough to engage lift in forward gears, it should work in reverse as well.
