have a ODB2 scanner and have a 420 on and off
power seems good, idle good
So far have done.
air filter
plugs
checked fluids all ok
Here are the plugs what do you think? What will i get for MPG now?
Thanks
Sure, I've been using the Torque app with both of our Vibes. I got the $25 OBDII adapter on ebay and it works well. Once I programmed everything in for each of them, the MPG is pretty much within 3% of my manual calculation or less. Lots of neat things to display, but mostly I just use it to monitor water temp and instant & average MPG and MPH. The travel time and route function is neat too.GregC wrote: Any one using Torque app ? any tips?
Thanks greg
http://torque-bhp.com/wiki/Boost_Adjustment" onclick="window.open(this.href);return false;The boost adjustment option in the vehicle profile can be used to correct for two things:
Atmospheric pressure adjustment - if you are significantly above sea level, and your vehicle uses a MAP sensor, then you may use this field to adjust your boost/vacuum readings to compensate for the reduced atmospheric pressure at higher altitides
Some vehicles (Mitsubishi Evo) may read 14.7psi even when the engine is off - this is due to the way the ECU is reporting data. You can use the field to adjust the pressure (put -14.7 in) so that it reads correctly for these vehicles
Keep the RPMs under 3000 when acceleratingvibolista wrote:Remember that driving style has a huge effect on how many miles you can get out of a tank of gas. Smooth and easy really helps... and stay near the speed limits when you can! Automatic Vibes do pretty well when it comes to MPG numbers.
I have an OBDIi adapter too and the free Torque app. When you say program everything in, you mean just setting up your graphs/dials in the app right? I dont think Torque is able to program anything into the cars computer right? I just use it to monitor mpg jnstamt and average. it would be nice if i could change the settings on the car though. I would like to change the shift points so that it shifts a bit earlier so i can get better mpg. im a smooth and easy driver and rarely ever punch it.trb wrote: ↑Sat Dec 29, 2012 10:38 pmSure, I've been using the Torque app with both of our Vibes. I got the $25 OBDII adapter on ebay and it works well. Once I programmed everything in for each of them, the MPG is pretty much within 3% of my manual calculation or less. Lots of neat things to display, but mostly I just use it to monitor water temp and instant & average MPG and MPH. The travel time and route function is neat too.GregC wrote: Any one using Torque app ? any tips?
Thanks greg
