New battery from advance auto - are you smarter than...
Chiadog
Post by Chiadog »
Just had a new AutoCraft Silver 26R series (575CCA) battery installed at Advance Auto, Cost $91.73. I decided to test this new battery by turning on the low beams with the engine and ignition off to see how long it would take to drain the battery to 50% or so.
I ended up running the battery down to 37% capacity. Any educated guesses as to how long this took? Low beams only, no fog lights or interior lights, etc.
12 Volt battery % charge chart:
http://www.mmbalmainauto.com.au/PDF/Sta ... teries.pdf" onclick="window.open(this.href);return false;
Chiadog :o
Re: New battery from advance auto - are you smarter than...
Hmmmm ...... Somewhere between 60 & 90 min? Just a wild guess :?
Fun science experiment, but not one I would do on a brand new battery I just spent $91.73 on. :lol:
beemerphile1
Post by beemerphile1 »
I could estimate the AH capacity of the battery and estimate the amp draw of the lights to come up with a WAG but I won't. Just thought I would point out that a new battery does not have full capacity until it has been cycled several times.
I like to use this chart;
Chiadog
Post by Chiadog »
tpollauf wrote:Hmmmm ...... Somewhere between 60 & 90 min? Just a wild guess :?
WE HAVE A WINNER HERE!!!!!
ACTUAL TIME FROM 100% TO 37% CHARGE: 80 MINUTES. Ding-Ding-Ding-Ding-Ding ..... that's the best i can do!
chiadog
Chiadog
Post by Chiadog »
ColonelPanic wrote:Fun science experiment, but not one I would do on a brand new battery I just spent $91.73 on. :lol:
Come On Colonel! Take a walk on the wild side!
chiadog :D
jake75
Post by jake75 »
beemerphile1 wrote:I could estimate the AH capacity of the battery and estimate the amp draw of the lights to come up with a WAG but I won't. Just thought I would point out that a new battery does not have full capacity until it has been cycled several times.
Does a battery ever get "cycled" if the alternator keeps it "topped off" so to speak?
09SnowyVibe
Post by 09SnowyVibe »
Keeping in mind, anytime you discharge a battery enough to dim the lights, you just lost 10-20 percent of its remaining life. Its worse when its freezing outside. If you must discharge a battery to that extent, consider a deep cycle battery.
I found when I put a trickle charger on my cars that sit in the winter, the batteries last alot longer.
2009 Vibe AWD
2001 Sunfire GTX
1993 Buick Park Ave
1984 Chevrolet Citation
jake75
Post by jake75 »
09SnowyVibe wrote:Keeping in mind, anytime you discharge a battery enough to dim the lights, you just lost 10-20 percent of its remaining life. Its worse when its freezing outside. If you must discharge a battery to that extent, consider a deep cycle battery.
So that's my problem - Ive drained my personal battery enough to dim my lights many times in my 70 years on this earth. I should have zero remaining life! And often I think I do have zero remaining life - or at least some parts of me are in that condition. :D
