It''s an '04 base 5-speed with Moons and Tunes, 91k miles
Front doors:
Alpine sps610c 6.5''component set 80w rms on a
Alpine mrv f300 4 channel bridged to 80w rms x2 @ 4 ohm
Rear doors:
Pair of kenwood wac 6.5 coax 50w rms on a
Rockford p4004 (see below)
Hatch:
2x Rockford p6903 6x9 60w rms
2x Kicker f8a 8" 8ohm 150w rms
All on a Rockford p4004 4 channel amp:
Front: 2x100w @2 ohm (kenwood 6.5 and Rockford 6x9)
Rear: 1x 200rms bridged at 4ohm (kicker 8")
2 kenwood w6006 12" 150rms on a
Rockford p400.2 2x 100rms @ 4 ohm
Mounted in a 1 cube sealed isobaric enclosure
2x kicker compvr 400w rms each
Each of them mounted in a ~2 cube sealed enclosure
On a Rockford 700s 750RMS @ 4 ohm bridged.
Power wire:
Knukoncepz 0/1 gauge between front and rear battery
Knu 4 gauge power from rear battery to amps and ground
Speaker wire:
Knu 10 gauge to each voice coil of the subwoofers
Knu 12 gauge for midrange and highs
1
Door as it looks untouched:
2
3
4
Inside of the door has:
3 layers 60 mil epdm emebrane
bottom 2/3 has 3/8'' gel floor mat
mold resistant carpet padding
memory foam piece for "polyfil"
Then padding:
rear door
I took the trim off to stop it from rattling. If you do this make sure you remove the 8 clips from the inside. If you don't you will break or bend them. Most importantly you can't get it back on.
Roof before:
After:
Note the space behind the sunroof is half covered, the padding i used was just thick enough to get caught on the last few inches of operation.
Skid plate/ splash guard. 3x3 sheet metal covered on both sides with EPDM membrane and bolted (many more times than shown) to the undercarriage. Goes from under the front bumber lip to just before the front wheels with some space for efficient airflow.
I needed to remove this ring from the plastic part and cut the endge of the housing so i'd have enough clearance from the door cover + foam for surround.
Tweeter: 2 watt 4 Ohm
Alpine sps 610c before
After
Make sure to cover the hole for the old harness from the inside
amp remote
Rear put back together
Rough cut of the rear battery
Rockford 700s guts:
Sail with foam to seal Alpine tweeters
Amps
Alpine mrv 300f
Rockford P4004
Rockford P400.2
Hifonics HFI2500D
Kicker Kx650.4
Only one of these amps is in full working order!
Anyone need?
Sub box: 2 kicker compvr 12s(older models than the one shown)
And 2 kenwood w6006 12s
