There are lots of small to mid size cars using 5x100 bolt patterns.
The offset's will be different, but as long as you're within 10mm it should fit.
95-05 J-Body +35
85-98 Grand Am +35
All Impreza's +45 (except STI)
All Legacy's +45
MkIII/early MkIV Jetta/Golf +40.
The bore fit will also be different.
Subaru hubs are larger, and will fit. I don't know about the other models listed.
If the bore is not the same size it's recommended you have bore spacers added to keep your wheels centered properly. This will keep the wheel bearings happy.
Have you tried looking
http://www.craigslist.org" onclick="window.open(this.href);return false; ?
How about these ?
http://cincinnati.craigslist.org/pts/3529900416.html" onclick="window.open(this.href);return false;
