But what year is yours? They changed the intake in 05 when they went to the drive by wire throttle, so it is different than the earlier cars. I'm looking for one for my son's 06 also.t(Double D) wrote:I have a K&N Typhoon on mine... and its a base model. It fit no problem.
Cosmoracing makes a short air intake for the 5-8 base models which will fit, no problem. That's what I have on my 06 base. I think they also make a cold air intake for those years' base, but I wanted the SAI since you can more easily remove and clean the filter on those. Oh, and I was scared to take off my front bumper.trbstang wrote:But what year is yours? They changed the intake in 05 when they went to the drive by wire throttle, so it is different than the earlier cars. I'm looking for one for my son's 06 also.t
It's a 15-20 minute job. You just need to remove a few push pins on the underside front of the fender liner, bend it back and there it is.cptnsolo77 wrote:I have been thinking about getting a CAI. Maybe I can squeeze out another 1 - 2 MPG...how difficult is it to access the filter when its time to clean it?
The filter is just above the fog light. Turning or removing the wheel helps.cptnsolo77 wrote:Thanks. Im guessing you have to turn the wheel all the way to the left to give yourself more room for removal ? Also how far down is the filter located?
