Will 11 Matrix wheels fit 06 Vibe?
Smokey06
Post by Smokey06 »
Hello all! New vibe owner and looking to get a set of winter tires. Found a set off a Toyota Matrix and I think they will fit.
Wheel size is 16x6 and lug pattern is universal 5x100 or 5x115
Am I right? 205/55R16 Wintercat XT mounted on steelies.
Thanks!
Take the road less traveled~Life's a journey, not a destination
Re: Will 11 Matrix wheels fit 06 Vibe?
Welcome to GenVibe Smokey :D Update your profile showing us your location. Anyways the answer is YES but it depends on which engine you have. The 1.8l will accept the smaller rims & bolt pattern and fit ALL Vibes with that engine, whereas the 2.4L will accept the larger ones and only on 2009-10 Vibes. Post pics of you're Vibe and let us know what you're up to. Again ................. Welcome ;)
2014 Silverado, 2004 Vibe GT
Exactly what tpollauf said...
2009-2010 2.4L Vibes & 2009-2013 2.4L Matrices = 5x114.3
2003-2008 Vibes & Matrices + 2009-2010 1.8L Vibes and 2009-2013 1.8L Matrices = 5x100
Scwmcan
Post by Scwmcan »
Yes smokey since they are universal fit with both lug patterns you will be just fine with then.
vibolista
Post by vibolista »
'06 Vibe steelie is 16 inch wheel with a 5X100 bolt pattern. The 2.4L engine 2009-2010 Vibe/Matrix have a different bolt pattern that will not fit the first generation Vibe/Matrix. Only the 1.8L engine 2009-2010 Vibe/Matrix wheels will fit the 2003-2008 models.
Here's just about everything you need to know about 1st generation Vibe/Matrix wheel sizes, offsets and bolt patterns. (these are the Toyota Matrix wheels, but same measurements apply for both cars)
Scwmcan
Post by Scwmcan »
You are of course correct for the OEM wheels, but the original poster was looking at universal fit wheels with both bolt patterns so they will fit without a problem.
