I have a few things due for replacement. struts, Tie rod end, and a bad strut mount. I don't want to cut any corners so I'm going to replace just about everything that could need it and then get an alignment. I'll be changing out the springs as well. here's what I'm thinking so far. anything else i should replace or check on? I know I've had to replace broken sway bar links on some other cars, I can't really think of anything else.
all new monroe strut mounts, New tokico blue struts, eibach pro kit springs, and outer tie rod ends.
I came across this and never heard of it. looks like it goes between the spring and the front upper mount so should I use two of these? are they not used in the rear they only seem to be for the front. know anything about this?
MONROE 906936 Coil Spring Insulator/Seat
http://item.mobileweb.ebay.com/viewitem ... 3832069046" onclick="window.open(this.href);return false;
I want to make sure I get new strut boots as well. my old ones are just about disintegrated so I can't tell do they just clamp on the top and bottom? are they universal size and the same front and rear?
these have an insert that says it keeps the strut from bottoming out. is there really a need or benefit to this assuming they fit?
KYB SB102 Shock Boot Strut Rubber Black Each
http://item.mobileweb.ebay.com/viewitem ... 1573817530" onclick="window.open(this.href);return false;
