Ok, so first off don't laugh :0
I'm putting in the trailer wiring kit in my 09 Gt, the type that has to run a wire to the battery. I only figure on pulling a light utility trailer a couple times a year so I want to get this done as easy as possible. I notice the kit comes with a 10 amp fuse... the cig lighter has a 10 amp fuse. The instructions that come with the kit say max stop/turn light 1 per side 2.1 amps, max tail lights 4.2 amps.... that's 6.3 amps. Seems I can just run the hot wire from the harness to the cig lighter, then coil it up & stow it in the rear side panel when not in use?
Yes?
Will I die?
