2009 Monsoon Head Unit Question
MannyL
Post by MannyL »
Anyone have a diagram of the head unit wiring? My audio in jack is damaged and I want to bypass it with an external jack. I'm not sure where to run the wires on the HU once my friend has it pulled.
viboflavin
Re: 2009 Monsoon Head Unit Question
Post by viboflavin »
Is it physical damage to the port?
If so, your best bet is probably to get right behind where it goes into the unit and solder leads to a new input.
I once took a CD audio output (from the disk tray) and soldered in an 8th inch female jack and trust me, you don't want to be messing with the circuit board if you don't have to.
MannyL
Post by MannyL »
viboflavin wrote:Is it physical damage to the port?
Yes it is physically damaged.
