I want to see your "100,000 mile" snapshot in the next couple days09vGT wrote: My Vibe has 99,900 miles on it
tpollauf wrote: I want to see your "100,000 mile" snapshot in the next couple days
google "toyota recall steering corolla canada" for a start. I have not bothered - I know the US Vibe recall is coming eventually. I can wait.Caretaker wrote:I just begged the genvibe masses for information in the Handling-Suspension thread as well. Hopefully our GM tech will chime in and update us with some good news soon even though these pages seem to get quieter and quieter as the months roll on.
Does anyone know what this rattling noise is? I have it too and it sounds like it is coming from the passenger side dash/glovebox area.TownDrunk wrote:Would this cause a rattling noise coming from the passenger side dash area? That's what I've been dealing with for over a year now.
After one miss diagnosis by the dealer believing it was my vibes steering rack, and then knowing the real issue through conversations with folks here on GenVibe is the reason I decided not to pursue replacing the steering column knowing the rattle could and probably would come back. The other reason is, I assumed it would not be a safety related issue and therefore would be safe to drive the vehicle without any concern. But if some of the corollas are having possible steering response issues, maybe I should have been concerned.XRVibe10 wrote:I'm curious to see what happens with this - i've posted a few items on here in regards to noise from steering columns - i've had to put 4 in my car alone under warranty for rattle noise over rough roads & at slower speeds - its not a safety related item, just a noise issue - i've put 20+ columns in 2009-2010 Vibes for the same issue of rattle noise - the Chevy Cobalts & Pontiac Pursuit/G5 have the same problem with rattle noise - The noise is related to the column mounted assist motor (in my opinion, this is what i've determined through many replacements) - (the new Rack mounted assist motor columns don't seem to make this noise) - I've given up on trying to fix it, it hasn't gotten any worse, its just there - the replacement columns i've put are the same ones coming out, so the issue isn't being addressed yet - maybe this new recall will (hopefully it comes to our platform), wait & see...
It could be just the seatbelt buckle tapping against the passenger door panel. That's the only loud noise that I hear every once in a while.Autofan242 wrote:Does anyone know what this rattling noise is? I have it too and it sounds like it is coming from the passenger side dash/glovebox area.TownDrunk wrote:Would this cause a rattling noise coming from the passenger side dash area? That's what I've been dealing with for over a year now.
it is nothing in the glovebox as i cleared that out. it appears to be a rattling knocking noise coming from behind passenger dash area. It is really annoying me. Any info would be helpful. Thanks.
So I take it this is related to the electric power steering - that replaced the old hydraulic system.XRVibe10 wrote:I'm curious to see what happens with this - i've posted a few items on here in regards to noise from steering columns - i've had to put 4 in my car alone under warranty for rattle noise over rough roads & at slower speeds - its not a safety related item, just a noise issue - i've put 20+ columns in 2009-2010 Vibes for the same issue of rattle noise - the Chevy Cobalts & Pontiac Pursuit/G5 have the same problem with rattle noise - The noise is related to the column mounted assist motor (in my opinion, this is what i've determined through many replacements) - (the new Rack mounted assist motor columns don't seem to make this noise) - I've given up on trying to fix it, it hasn't gotten any worse, its just there - the replacement columns i've put are the same ones coming out, so the issue isn't being addressed yet - maybe this new recall will (hopefully it comes to our platform), wait & see...
The passenger seat back will rattle too depending on the angle it is set at when going over bumpy stuff.ParknVibe wrote:It could be just the seatbelt buckle tapping against the passenger door panel. That's the only loud noise that I hear every once in a while.Autofan242 wrote:Does anyone know what this rattling noise is? I have it too and it sounds like it is coming from the passenger side dash/glovebox area.TownDrunk wrote:Would this cause a rattling noise coming from the passenger side dash area? That's what I've been dealing with for over a year now.
Very helpful & informative links. After reading most of them and hearing that it is likely the electric motor part of the column, I wonder how long before this escalates to a Pontiac TSB, OR an actual recall. Not holding my breath just yet10vibe wrote:A few links that probably has already been posted, but might help in the hunt of info.
tpollauf wrote:Very helpful & informative links. After reading most of them and hearing that it is likely the electric motor part of the column, I wonder how long before this escalates to a Pontiac TSB, OR an actual recall. Not holding my breath just yet10vibe wrote:A few links that probably has already been posted, but might help in the hunt of info.
This is a trend that is affecting many companies. When there is a problem, it usually affects more than one manufacturer since they use some of the same parts, sometimes with only cosmetic, outer cases or mounting differences. A window switch that catches fire might nail a Chevy, Honda, and a Toyota. There have been a bad batch of water-pumps too that might go across several manufacturers. These column mounted EPS's have been put in a lot of different cars.jake75 wrote:I wonder if part of the problem is that years ago the auto manufacturers made the auto parts. Now, save for the basic engine, transmission and body all the parts seem to be made by outside suppliers.
