NO SPEED 5 SPEED.............
mango02
Post by mango02 »
I understand buy is cheaper than try to RE-BUILD. Can you Rebuild or is the case, forks and other stuff trash? I do not want to buy another junky box.
Re: NO SPEED 5 SPEED.............
From what I've read about the failures, when the bearing goes it takes the housing with it so rebuilding would be next to impossible. So don't waste your time, just buy the 6 speed.
mango02
Post by mango02 »
Almost cheaper to buy an Automatic Transmission and convert the car to Auto.
not really. You'd need the shifter, a new radiator that includes the tranny cooler, and oil lines from the tranny to the radiator, and a new auto tranny computer/ECU. I don't know if the axle shafts are the same. Plus the tranny, of course. The manual tranny brake master cylinder also includes the master clutch cylinder, so If you were switching from an auto to a manual, then you'd need to replace the master brake cylinder but to go from manual to auto you could probably cap off the clutch part and leave that half unused.
Usually vibers replace their 5 speeds when the bearing noise becomes apparent. If yours is past that to the point where none of the gears work, then it must be really trashed inside, and a rebuild would be way more expensive than a replace.
since you have two threads on this topic, I'll post the link to the other one as a cross reference viewtopic.php?f=12&t=39695" onclick="window.open(this.href);return false; so interested people can find the other half of the discussion
hotbug1776
Post by hotbug1776 »
it's around $2500 for a new transmission. That's either with the new 5 speed, or the new MWR JSPEC 6 speed (same FDR as the 5 speed) so if you are wanting a bit more performance with the same MPG, go 6spd. If you want a new 5 spd, redesigned to not fail, then I'd go through a shop to get one.
thebarber
Post by thebarber »
you can get low-mileage c60's for $6-800
thebarber wrote:you can get low-mileage c60's for $6-800
I couldn't remember, had to look it up
C59 is base 1ZZ 5 speed manual,
C60 is GT/2ZZ 6 speed manual
The auto trannies were
A246E Base/1ZZ FWD Auto
U240E GT/2ZZ Auto
U341F Base/1ZZ AWD Auto
hotbug1776
Yes, but not with the 5 speed final drive ratio. That makes a huge difference on the highway when it comes to rpm's with the 1zz. Don't get me wrong, I'd take whatever I could get just to have the 6 speed.
thebarber
Post by thebarber »
the 6speed is worth it despite the final drive putting your rpms a few hundred higher
i still get great mileage in my 03GT....the 6 is better around town though....easy to keep it under 3000rpm without lugging the engine
SeattleJeremy
Post by SeattleJeremy »
hotbug1776 wrote:it's around $2500 for a new transmission. That's either with the new 5 speed, or the new MWR JSPEC 6 speed (same FDR as the 5 speed) so if you are wanting a bit more performance with the same MPG, go 6spd. If you want a new 5 spd, redesigned to not fail, then I'd go through a shop to get one.
If you don't get the LSD, the 6-speed with the 5-speed FDR is only $2000 ;)
http://www.monkeywrenchracing.com/produ ... ts_id=1665" onclick="window.open(this.href);return false;
Edit: $1800 if the shifter shaft on the 5-speed can be reused.
hotbug1776
Even better then!!!
hotbug1776 wrote: Even better then!!!
I totally agree :D For someone wanting to keep their vibe for a VERY long time, it would be money well spent from a reputable shop!
SeattleJeremy
hotbug1776 wrote:Edit: $1800 if the shifter shaft on the 5-speed can be reused.
I emailed Monkey wrench racing. When installing the listed 6-speed in a 5-speed car the 6-speed shifter shaft is required. But still $2000 for a new 6-speed transmission is way better than the $2450 Toyota charges.
mango02
Post by mango02 »
Will remove and tear Gearbox down, trying to Rebuild my gearbox before I buy. Will post as soon as I can see the damage inside. Remove Fly wheel and re-surface also change Oil seal. Have I missed anything I should do??????
Post pics of the inside. I have a spare bad one,and would like to know if there's any cool looking parts inside worth taking the thing apart to get at. ;)
