So, I had my tires rotated earlier this year. The shop that rotated them did a terrible job to the point where if I went above 60 mph the steering wheel would vibrate badly and even pull to the right a little bit. I took it back and they "fixed" it, essentially eliminating the vibration, stating that the problem was with the balancing. It still pulled to the right slightly.
The worst part is that suddenly, the outside treads on my left front tire wore down VERY quickly, within a few months - much faster than the other tires.
I tried an alignment later to see what would happen. It didn't solve my pulling problem.
So, when I got my transmission fluid changed at the local Toyota Stealership (a different shop), I got my tires rotated as the left front tire was essentially bald on the outer rim (the rest of the tire is actually ok) so that I would have better traction in wet weather. So...now my car pulls to the left ever so slightly...and the tire that is now on the front left of the car is experiencing similar wear as the other one (which is now in the back until I put enough change together to replace them).
I'm baffled...what could be wrong here? All my other tires are wearing down relatively well, although one seems to be leaking air faster than the others.
