2010 Corolla Wheels fit 04 Vibe
FAHQ
Post by FAHQ »
Greetings,
I found a set of 4 16" wheels from a Corolla S on Craigslist for cheap. I am wondering if they will fit my wife's 2004 Vibe. I'm 99% sure the bolt pattern is the same. I'm just wondering if the backspacing is the same. Just looking for some insight before I drive down there and say "Hey, mind if I pop one of my wheels off and see if it fits?" CL is ripe with weirdos and I would rather not be one of them. Thank you in advance for your responses.
Cheers
Re: 2010 Corolla Wheels fit 04 Vibe
Should fit without a problem. I see the Corolla 16" are 6-1/2 wide, which is the same as the Vibe wheels. If the offest is different, it is probably only a few mm and that will not make a difference. 6mm is about 1/4"
cptnsolo77
Post by cptnsolo77 »
I could be wrong but I thought the 09 Corolla, Matrix & Vibe had a different bolt pattern than the 03 - 08 models? I know through this site that the 09 wheels Vibe wheels dont fit the 03 - 08 Vibes. Just checking here, I eventually like to upgrade to some alloys myself & the Corolla S has some really sharp looking factory wheels.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
cptnsolo77 wrote:I could be wrong but I thought the 09 Corolla, Matrix & Vibe had a different bolt pattern than the 03 - 08 models? I know through this site that the 09 wheels Vibe wheels dont fit the 03 - 08 Vibes. Just checking here, I eventually like to upgrade to some alloys myself & the Corolla S has some really sharp looking factory wheels.
No, it is only the 2.4L Vibe and Matrix with the different bolt pattern. The 1.8L Vibe & Matrix still have the same 5x100 pattern as the older ones and the Corolla which still has the 1.8L. And I checked on tires.com. It shows the 5x100 bolt pattern on the 2010 Corollas
cptnsolo77
Oh wow, thats great ! hmmm....going to look at craigslist right now LOL.
