2003 Vibe, 1.8L, 5 speed, 96k miles. Recently replaced cat after getting ongoing low bank code, etc. Replaced cat and code went away, improved idle slightly. 5k miles ago I replaced the spark plugs (but not the coil packs) (plugs were ashen, etc., car ran better after that, some power came back).. Heres the thing:
Once car is warmed up, when I come to a stop and put it in neutral, idle will sometimes stay at 750, all good, or will dip down to 500, idling rough.. If you watch the tach: sometimes it will be idling fine at 750 and then will rev up to 1000rpm on its own for a second and back down to 750.. I checked for vacuum leaks and there doesn't seem to be any. So, here is where I'm at:
Wife's car.. We waited too long to do some basic maintenance and then did it all at once: Brakes/Rotors(cuz we waited too long), Tires, Shocks/struts & then the clutch started slipping so we replaced clutch assembly and flywheel. Grand total - $2300. So, I'm not too keen on spending more money on this heap right now. Its running splendidly except for the random idle issue. I have seen this mentioned in various threads but the issue seems case specific and annoyingly, could be a number of things. SO, being that my automotive knowhow/tools etc. is around basic to intermeidate, what can I do before bringing it to a shop.
Replace PCV valve? Clean MAF sensor? How complex is the throttle body cleaning? Any other ideas.
Thank you and much appreciated. I have the Chilton manual for the car as well so I can def do some basic troubleshooting stuff before paying somebody $80 an hour to 'troubleshoot' for me.
THANKS
