Greetings Gen Vibers!
I've been spending the better part of the morning reading the myriad posts about serpentine belt replacement and am, so far, stuck on finding the correct belt to order. As I gather, the Goodyear Gatorback brand of belts is the best bet, but I want to make sure I'm buying the right size.
The model Vibe I have is:
2006 Vibe GT
This is the item I have found so far that seems the most promising:
http://www.amazon.com/Goodyear-4060747- ... automotive" onclick="window.open(this.href);return false;
Is this the correct size? According to my research, this Goodyear part is:
Belt Length (in) 74.75 in.
A little background of what I'm trying to correct - the car just crossed 60k miles and upon cold start, occasionally will emit a constant (pulsing in intensity) squeak coming from the area where the belt is. It sounds an awful lot like a belt as well. I'm hoping that this relatively simple and cheap fix will correct it. Also, the belt has 60k miles on it and probably needs replacing.
Another issue I need help with...
When my air system is turned on, be it heat, A/C, recirc or otherwise, if the fans are blowing, they chirp, like a squirrel and it drives me NUTS. If I turn the fans up in speed, it goes away for a few minutes but ultimately comes back. Anytime a fan speed is maintained for a certain amount of time, the chirp starts back up- is there something I can superlube to get this chirping to go away?
Thanks in advance!
-Casey
