" STICKING " ignition swith ??
Esteban
Post by Esteban »
Every so often, when trying to start my 2010 Vibe, the ignition switch gets " stuck " in a forward starting position. The starter just keeps spinning & it doesn't start. I can remove my hand from the key & it still spins over. I have to manually turn the key to off & try again. Of course, it wouldn't do it when the dealer was looking at it. Anyone had this problem ? Would it be covered by warranty even if the car is out of its 3 yr. warranty ?
Re: " STICKING " ignition swith ??
Does the key get stuck in the start position or does the car continue to try to start (but doesent) and keeps turning over with the key in the "on" position?
The car is equiped with an auto start feature in which the starter will continue to spin even after you turn the key from "start" to the "on" position. If the car is doing this, and not starting, it's not a problem with the ignition switch itself.
Esteban
Post by Esteban »
The key & switch is stuck in the start position.
Esteban
Post by Esteban »
OOPS !
When I try to start it & turn the key to start & let go of it, it goes back to " ON " position & motor keeps spinning over without starting. I must manually turn the switch to off & retry, which usually works. The car is just out of its 3 year warranty . Whatever the problem is, would it be covered under any warranty at all ??
In a quiet area, have someone turn the key to the "on" position, not "start", while you listen under the car for the fuel pump. That would be the first thing I'd check.
How far time/mileage wise is it out of warranty?
Esteban
Post by Esteban »
I'll try to listen for the fuel pump. Car was out of 3 yr warranty in Aug & it only has 22,000 miles on it.
