2006 2WD Automatic. My radiator fan will not turn on. I first noticed it when when my AC would not cool at low speeds. Luckily the engine doesn't overheat even down here in FL, but I'm usually not stopped for more than 5 minutes at a time at a traffic light.
I've checked the 40A fuse and it is good. I don't know where the cooling fan relay is to check and I have not yet tried to jump the fan motor to test it (I assume I can jump a lead wire from positive battery to get it to engage while negative side of motor is grounded?).
I'm guessing it could also be the coolant temperature sender\switch, which I also don't know where it's located.
Spinning the fan manually, I don't feel any bearing grinding, but it does seem rather loose.
Help on the location of these components would be a great help (coolan temperature\switch and cooling fan relay).
Thanks.
