Rear wheel alignment shim installation???
Chiadog
Post by Chiadog »
Has anyone installed rear wheel alignment shims on their Vibe? Does this require removal of the brake drum? Any other info?
My right rear wheel toe-in has a little too much toe-OUT.
Thanks,
chiadog
Chiadog
Re: Rear wheel alignment shim installation???
Post by Chiadog »
UPDATE:
Did the rear wheel alignment shim job today! Very easy once you understand the weak instructions, although Midwest rust made separating the bearing carrier from the suspension sort of difficult. Didn't have the alignment re-checked, but the car no longer drifts left on the hi-way. Score!
chiadog
KNINE
Post by KNINE »
I had an alignment shop install mine.
Chiadog
Post by Chiadog »
Hey K9,
What did they charge you for the rear alignment shim installation? One side only?
Doing it myself cost $12.00 for the plastic shim and 2 hours of labor.
An hour of that was hammering to break the rust bond. :D
chiadog
Digglesworth
Post by Digglesworth »
I am also curious as to how much the shop charged. I'm putting tein s-techs on mine and someone else who installed the springs said he had a tiny bit of negative camber and had to shim the rear....
2009 Vibe GT
Magnaflow cat-back - K&N Typhoon SRI - Tein S Techs - NGK iX's
5400k Xenons - Shorty Antenna - Curt 1.25" hitch
