i cleaned everything before the new battery went in 4 WEEKS AGO. I have more tools than most. I replaced the battery because it was the original and 90% of it is w/short trips in city.. And the cranking speed seemed slow to me. Even when warmed up. It cranks quickly now. I have both the new and old battery. Both showed same symptons=
low voltage when hot. So it's not a battery issue. I am trained in electronics...and know when things are not operating good electrically. I suspect the voltage regulator is bad...it's internal on these. Below 13v at idle should never happen. And bearings can go bad anytime...so I am told. Which could cause "brush" issues or worse. I suspect the internal regulator is bad. Simply because the issue happens under the hottest conditions. Which is not unusual for a failing electronic part. But I just do NOT know
who sells good quality alternators and who does not ? I can get a NEW one not remanf. for $150..REMY brand from Advance. REMY does manufacturing world wide.
http://www.remyinc.com/new.aspx" onclick="window.open(this.href);return false; How they make it for so little $$ new is beyond me. FYI- Autozone does not give refunds on any electrical item. Even if it's bad out of the box. So you are stuck with it forever and they might replace it. But never give $$ back if you are frustrated with the quality...So I stay-away from them. ANy knowledge of good or bad brands is helpful. Actually I looked...it's 88k on the old girl.
