Has Anyone ever measured the Vibes auto transmission atf fluid pump rate at engine idle speed?
If so, an EZ fluid exchange would be: drain/refill - run engine at idle 3.2 qts. worth - drain/refill - repeat.
Total fluid added = about 9 qts. with very little mixing of old and new fluids.
chiadog
