Wheel well liner
Wheel well liner
So the front wheel wells now have holes in them. I'm replacing them ASAP, but I'd like do know: how can I keep this from happening again? I've had the car for 6 years and the holes only just got worn into them within the last week, so I'm guessing some clips finally wore out and the liner came a bit loose?
If it's clips, are there any other clips I should be watching or replacing? I feel ashamed of myself whenever a part starts hanging off because the clip died! :oops:
Re: Wheel well liner
There are many clips like this on plastic around the front end. Check the ones on the splash shield below the rad.
bluneon
Post by bluneon »
the clips are designed to be sacrificial. they are meant to break and fall off during any hard enough impacts on the bumper/shield/liner or parking block hit. that way the shields stay intact, if only for a little bit until the shield drifts too close to moving parts.
if the clips weren't designed to break off, then the shields will rip and tear. the shields costs a whole lot more than the clips themselves.
unfortunately the only way around it is to stop hitting stuff on the road. or you could secure the clips w heavier clips, but run the risk of ripping or tearing the shield if/when you hit something.
I need to replace a few clips on my fender liners and the body side trim also, and found they are pretty cheap at Oreilly or Autozone, like $5 for 20 clips or so. But first I need to get the front splash shield since the prior owner broke it off somehow, and now the whole bumper cover rattles. :(
Someone found the fender liners pretty cheap on rockauto.com
Good luck!
Update!
I got the driver's side liner on, but the back part that's held with the self-tapping screws is now without the clips that the screws screw into (due to Dad and me brutally murdering them while pulling the old one off). I don't know where to get these clips or how to install them once I have them because they have a washer-shaped head that fits between the fender and the exterior plastic cladding, then a square plastic peg that sticks through the wheel well liner.
I know, we shouldn't have killed the plastic clips on that part, but I didn't know they were what the old liner was hooked on. I assumed that some rocks had gotten wedged in along with the entire handful of dead leaves I found in there or something :oops:
cptnsolo77
Post by cptnsolo77 »
I just used black cable ties in my rear wheelswells after I reinstalled the rear bumper. Cheap & effective. Cant see them anyhow. Good ol' needle nose & they will be super tight LOL.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
