I am a Toyota loyalist so given the Vibe is basically a Toyota I feel comfortable purchasing one, or at least inquiring about one!
Thanks in advance for any and all input!
2008 should be fine as far as transmission goes. The problem years were 2003-04 (early to mid 04). I feel the car would be better all around with a 6 speed (Japanese, not American) as the gears are a tad long for my tastes.xcmtb83 wrote:Thank you for the information.
So I take it the manual trans are not very reliable? Can you explain? I am interested in this because I would prefer a manual trans but the Ms. would like an auto.
Thanks in advance.
Two words... Refinish Restorerxcmtb83 wrote:I want the base because it has the gray trim on the bottom what will hold up to gravel better than paint (live on gravel road).joatmon wrote:2008's only came in base and AWD, the unpainted lower plastic cladding is the lower cost trim option available on both. I have the unpainted cladding, and it's ok I suppose, but looks bad if you ever get wax on it, so watch for that if you buy it.
