So, I'm working on adding a vacuum controlled switch to automatically shut off the A/C when passing or climbing. Basically any time you are in need of power when on the road and have the A/C on.
All the switch will do is deactivate the A/C at a certain throttle opening the power it back up at cruising speeds. Old Tele Man suggested this on an Eco mod site, and, I think I'm going to run with it.
Any suggestions to help make this better are appreciated. I'll be using the Superior k-058 switch to make this happen.
