elctric window problem=
jamesmetairie
Post by jamesmetairie »
2003 with electric windows.
1st time problem=
today the drivers window jammed going down about half way.
it wouldn,t budge.
then later it worked ok.
anyone having any window motor or track problems?
note = couple of years ago i brought the vibe in to a dealer for the "recall" work to do with the bolt in the door affecting the window.
bluneon
Re: elctric window problem=
Post by bluneon »
make sure the bonded tabs in the glass aren't broken off the glass.
christo
Post by christo »
I think I know what is your problem... I have the same with my 05 non-power window...
On my side, there is a part in the door that is coming in contact with the window : The little arm that avoid the door to open too large
sideshowalan
Post by sideshowalan »
Could be several things.
-glued tabs on bottom of the window that have already been mentioned.
-bolts that keep the tabs connected to the track have come undone.
-door check getting in the way.
-bent regulator.
Only way to tell is to take off the door panel and see what's in the way.
In mine it was the glued tabs that came undone.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
