To joatmon: many thank for the idea with the DIY tap tool!
Just got my hidden hitch mounted and it was fairly easy.
First tried to get a tap tool or 12x1.25 bolt from Home Depot and Lowes.
No luck at both places. Then went to ACE hardware and they had both.
Tap was around 7 bucks, bolt like 3-4. Decided to go with the bolt for two reasons:
1. Taps are sharper and there is a chance of messing up the thread big time
2. Bolt is more compact and I was worried about the left side where the exhaust pipe is
Used some WD40 as it was advised here and everything was very fast and easy.
It took some rust and road dirt I guess. The pic is after one hole. I cleaned the bolt after each one.
Thanks again vibers!
EDIT: Had to add the pic using the PC since I couldn't find how to attach it using my iphone.
Another thing I forgot: The guys at ACE were very helpful and they used a dremel tool to cut the slots for me.
