Sounds like you already intend on passing the factory amp. I honestly thought that the factory amp wouldn't produce anything great, but my assumption is it's more based on your head unit. The one I have, Kenwood KDC-HD942U, and just using the Schoshe (sp?) wiring harness to stil luse the factory amp has produced amazing sound. I hear things much better than before. The only downfall I have now is since I replaced the factory sub with an aftermarket 6.5 sub, I've lost the nice bassier mids that it produced.mac77daddy wrote:...I have heard that in addition to installing the new Head unit I will have to bypass the stock amp for good sound quality. 1, is this true?...
Thanks for your input. I have now decided that I am going to try this in stages. I am going to install the head unit with the wiring harness (like you) and see how it sounds. The new Kenwood that I have has built in, fully adjustable, HP crossovers front and rear (controlled individually) then subwoofer frequency/level/phase control as well. I chose this unit because of the extensive control of sound. If I don't like the way it sounds running through the stock amp then I'll look further into bypassing the factory amp. So, would you say that there is less distortion at high volume than the stock head unit?Wolfman213 wrote: Sounds like you already intend on passing the factory amp. I honestly thought that the factory amp wouldn't produce anything great, but my assumption is it's more based on your head unit. The one I have, Kenwood KDC-HD942U, and just using the Schoshe (sp?) wiring harness to stil luse the factory amp has produced amazing sound. I hear things much better than before.
The colors dont match or the printing of what the wires are for on the harness wire dont match?novibeyet wrote:Still looking for answers...2009 GT with moons and tunes.....I picked up a used kenwood excelon 9140 that I want to install. I have tried 3 harness kits....none match the stock plugs on the existing radio.
I had an online chat with Cructhfeld, they could not find a harness. I am trying to avoid doing the hard wire. Anybody have any clues......please.
if not any links to how to hard wire?
thanks.
Well that def sux :/ I don't have any white noise at all, which is one of the reasons why I suggested that method first. Well best of luck bypassing the factory amp!!mac77daddy wrote:Okay, so I installed the new head unit using the stock amp and I have to say that I am not that impressed. I definitely notice a difference in clarity but I also hear the white noise at lower volumes and I have my volume offset all the way down. I think that I am going to jumpover the stock ampand run it that way. We'll see how it works out. I'll keep you posted.
http://www.autotoys.com/x/product.php?productid=22155" onclick="window.open(this.href);return false; GMOS LAN 12 is the one that I used. This may be a bit overkill if you don't want to retain all the functionality.novibeyet wrote:Still looking for answers...2009 GT with moons and tunes.....I picked up a used kenwood excelon 9140 that I want to install. I have tried 3 harness kits....none match the stock plugs on the existing radio.
thanks.
thanks.
Wolfman213 wrote:Yes that guy is trying to screw you over. The adapter for the M&T is $30 at Crutchfield and it's the PAC model. When I got my HU, it was $50 and the Schosche (sp?) model. Just ensure that you are getting the correct one for the M&T and not just the base stereo though.
There are some members that do rewire everything, but that's simply because they are bypassing the stock amp, not a security device.
