I got my vent, door sill, and 3rd brake light stickers today. I was reading the directions and it says to apply soapy water, is it needed or can i just put them on dry? If i use the water with the hairdryer how long do i need the heat applied to the sticker before it is fully stuck? It also says to apply the soap to the vent stickers on the back, but some pieces are so small how the hell do you hold on to them? And it says to use a credit card to smooth out the bubbles, it seams as though that might rip, or tear the stickers, no?Thanks for any help
just take your time. tweezers work really good for those small partsvents:yes use soapy water helps to set them in place. you will know how long to use hair dryer they will form fit to the vents and look like they were painted on, you can press on the vent decals to get the water out from behind them while heating them. its very easy. the third light: soap and yes you can use a credit card over it they are pretty strong just brush over the decal lightly till you remove all air and water bubbles.never seen a door sill decal but it can't be much different than the vents.have fun
