NEED PCM HELP!!!!
Zvibe2004
NEED PCM HELP!!!!
Post by Zvibe2004 »
im the guy who just swapped my vibe from a automatic to a 6 speed, and i need to find someone that can reprogram my computer so it runs properly all the time and doesnt think the automatic just went poof-gone. from what ive found a toyota performance tuner, a guy that actually tunes toyotas pretty much for a living, could redo my pcm so it will be right. i have a pcm out of a 2004 corolla 5 speed, but with that pcm installed, my vibe wont start. i need to find someone that could either reflash my factory pcm to be a manual trans pcm or that could VIN flash the corolla pcm so my car will start and run. i need to find someone as close as possible to Ironton, Ohio, Huntington WV is close enough for a search. im pretty much relying on u guys to help me find someone, because ive looked all over around here and found nothing. this is the last thing i need to do to have my vibe 100% done. i absolutely NEED all the help that can be given right now with this. any leads will be greatly appreciated
2004 Base Vibe, 134,000 on the clock and still tickin'
born automatic, NOT ANYMORE!!! it's a 6 speed now!! :D
its gonna be a mean vibe someday, to about the tune of 350-400 whp ;)
Re: NEED PCM HELP!!!!
You could try giving your local GM dealer a call, in theory they should have all the tools to do it.
Hunt around at the wreckers for a Vibe GT or call around for a PCM.
