I'm new to this forum so thanks in advance for any help! I'm looking to replace the brake pads on my 09 Vibe base but I'm having some major issues getting the E brake piston to recede. The fronts were easy as pie to do but I'm having hell of a time getting the E brake piston to recede on the rear calipers. I have the caliper tool and I'm twisting it down clockwise but it won't budge... any suggestions? I've already removed the brake master cylinder reservoir cap and the bleeder screw with no change.
Also, the driver's side rear caliper has a torn dust seal boot so I'll need to take the caliper in for repair. Any suggestions on how to disconnect the caliper completely? Do you just remove the brake line and that torx screw?
Thanks again for the help!
