Got a question on installing a Throttle Body Spacer!
xTiaanx
Post by xTiaanx »
The engine has two braces that are holding the intake manifold to the engine (besides the 4 bolts that is already holding it. What do I do with these braces?! Are they a must have? Or can I compromise by removing the braces and just driving on the 4 bolts that came with the spacer? Need help ASAP!
Email me at: twsoccerboy@gmail.com
BlueCrush
Re: Got a question on installing a Throttle Body Spacer!
Post by BlueCrush »
xTiaanx wrote:The engine has two braces that are holding the intake manifold to the engine (besides the 4 bolts that is already holding it. What do I do with these braces?! Are they a must have? Or can I compromise by removing the braces and just driving on the 4 bolts that came with the spacer? Need help ASAP!
I removed the brace when I had my TB spacer installed. Never had an issue.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
xTiaanx
Post by xTiaanx »
There are two braces though. did you remove both?
