I would like to know why there's no light on the dash that indicate that the fog light are on/off. Usually there's always a light that indicate that the light are on/off... It's not usefull when is dark outside (because you can see if the fog light are on/off) but during the day it's pretty annoying... you must check if you're fog light's switch is on or off.Another thing, do you thing that it's easy to place a small light that turn on when the fog light are on ?? Thanks[Modified by Dan, 9:02 PM 9/20/2002]
[Modified by Dan, 9:03 PM 9/20/2002]
