I have had the Check Engine light scanned by two different shops and both times it came back as the 02 sensor - I had the O2 sensor replaced in September and both scans were after the installation. One of the shop guys mentioned it is probably a bad ecu and I would need a replacement. I would like to buy a used one off eBay and get it flashed. Anyone go through this? I have a 2004 base AT; thanks for any help/suggestions!
what were the codes?If they were what I think they were, no an ecu isn't going to fix it.Till you post the codes we would only be speculating what is wrong.
From my understanding these ECUs can't be re-flashed for performance. Now I heard about guys in europe are doing but yet havn't seen any posting on it
