::GeoffGT's Garage:: 2009 Red Hot Metallic GT
GeoffGT
Post by GeoffGT »
This is right after I bought the car.
The dual-tone Wolo horns, painted red.
Just a little red paint under the hood.
Got the windows tinted. I forget what percentage but it is the same all around.
K&N Typhoon installed.
GM Window visors. I went with these for the nonfunctional but cosmetic "3rd" window. Continuity is my friend.
Custom ScanGaugeII install.
Random shot.
...Used to be DressedInBlack...
Re: ::GeoffGT's Garage:: 2009 Red Hot Metallic GT
Glad to see you're back Geoff :)! I'm looking forward to seeing more pictures of your Vibe again! Have you done anything new to it lately?
journeyforce
Post by journeyforce »
I like how you mounted that ScangaugeII. How do you have the cord to the OBD2 connector routed? I got a cheaper scan tool. I got the Ultragauge since I could not justify spending $150 for the SGII when I could get this one for $69 and it does what I needed to do. I have a 2012 Scion XB and Toyota went cheap and dropped the temp gauge for a full time clock. I got this Ultragauge just for the temp and battery voltage
Here is a pic of mine in my XB
Keep up the good work on your car
GeoffGT
Post by GeoffGT »
Hey it's good to be back Carrie! Thanks. I haven't done much lately. I did paint the calipers though. But that's about it. I did the gold color. Wanted something different than red or yellow. :D
Thanks for the kind words Journeyforce. My buddy did the custom install on the SG2. The cable is routed under the dash to the OBD2 port; it's basically just tucked up behind everything. In hindsight, I wish the gauge was angled toward me just a bit, but oh well. I like the display on your gauge! Very clean.
GeoffGT
Post by GeoffGT »
Gold calipers
LED strips on my buddy's 4-Runner and my Vibe
Derf
Post by Derf »
LED Hood lights,... :D drat another thing I will have to add to my to do list!
Did you use a tilt switch, or jare they on a manually operated toggle switch.
Looking good Geoff ;) You can never go wrong with LED lighting .... even if it's under the hood! Keep up the good work!
